Hello together,
I need your help. I have been using an AC86U with amtm etc for a long time and everything works as it should. Now I have for the 30th time Skynet installed to hope for additional benefits through security.
Unfortunately, I was always disappointed and in the end I had to reinstall mostly all to work around the errors.
Short compilation:
The Asus router is connected to the Fritzbox, which also provides access to the Internet. On the Asus router is a VPN server installed, here I connect my devices outside the network. (Smartphone etc.)
Now Skynet blocks the internet connection of the devices in an untraceable rhyme. That is, browser activities are no longer available except the login to the router. Followed sometimes by wifi access blocking.
I have consequently added the network devices to the whitelist with the IP. Unfortunately this does not help? It keeps blocking... rebooting the router will help for about 24 hours until the Fritzbox gets a new IP from the network provider.
GLM would be my laptop being blocked. Over time, the other devices in the network (block outbound) 192.168.1.138 also collect here
greetings
Short compilation:
greetings
