Solved Skynet Blocked Devices Question
DJones
Top 10 Blocked Devices (Outbound) Great now what were they blocked for? We have Top 10 Blocked (Outbound), but no way to associate them with which device. Unfortunately this makes figuring out what the issue is really hard to troubleshoot. For some I can guess, but the firewall logs are gibberish to me.
This is likely a common question.
Follow up question does Skynet make Aiprotection get less hits? Since I've got this router I've had zero hits I don't use Malicious Sites Blocking, but Two way IPS and Infected Device Prevention And Blocking has been zero. I've attempted to try pen testing it using the usual recommended sites from this forum with Malicious Sites Blocking on or off and it stays zero. Also tried clearing the stats of Aiprotection in ssh. I kind of wonder if Cloudflare DoT could also lower hits as well with DNSSEC and Rebind Protection Enabled.
Just curious. I don't think theirs any actual issue my network.
Example Stats Commands;
( firewall stats ) Compile Stats With Default Top10 Output
( firewall stats 20 ) Compile Stats With Customizable Top20 Output
( firewall stats tcp ) Compile Stats Showing Only TCP Entries
( firewall stats tcp 20 ) Compile Stats Showing Only TCP Entries With Customizable Top20 Output
( firewall stats search port 23 ) Search Logs For Entries On Port 23
( firewall stats search port 23 20 ) Search Logs For Entries On Port 23 With Customizable Top20 Output
( firewall stats search ip 8.8.8.8 ) Search Logs For Entries On 8.8.8.8
( firewall stats search ip 8.8.8.8 20 ) Search Logs For Entries On 8.8.8.8 With Customizable Top20 Output
( firewall stats search malware 8.8.8.8 ) Search Malwarelists For Specified IP
( firewall stats search manualbans ) Search For All Manual Bans
( firewall stats search device 192.168.1.134 ) Search For All Outbound Entries From Local Device 192.168.1.134
( firewall stats search device reports ) Search Previous Hourly Report History
( firewall stats search invalid ) Search For Invalid Packets
( firewall stats search iot ) Search For IOT Packets
( firewall stats search connections ip|port|proto|id xxxxxxxxxx) Search Active Connections
( firewall stats remove ip 8.8.8.8 ) Remove Log Entries Containing IP 8.8.8.8
( firewall stats remove port 23 ) Remove Log Entries Containing Port 23
( firewall stats reset ) Reset All Collected Logs
Incredibly useful thank you!
Also failed to check your github.. my mistake.
