Skynet Skynet I found a menu without an Exit or Back option
smallnet
I was looking around in Skynet, and just realized that there is one submenu where there is no "Exit" option. I think there should be?
Basically, from main menu, select [11] which is Settings, and the submenu has no Exit button. If you go in by mistake, the way to "escape" is to toggle an option, then remember to go back in and toggle it back to how it was.
93406 IPs (+0) -- 47078 Ranges Banned (+0) || 2462 Inbound -- 530 Outbound Connections Blocked!
Select Menu Option:
[1] --> Unban
[2] --> Ban
[3] --> Malware Blacklist
[4] --> Whitelist
[5] --> Import IP List
[6] --> Deport IP List
[7] --> Save
[8] --> Restart Skynet
[9] --> Temporarily Disable Skynet
[10] --> Update Skynet
[11] --> Settings
[12] --> Debug Options
[13] --> Stats
[14] --> Install Skynet
[15] --> Uninstall
[r] --> Reload Menu
[e] --> Exit Menu
[1-15]: 11
Select Setting To Toggle:
[1] --> Skynet Auto-Updates | [Enabled]
[2] --> Malware List Auto-Updates | [daily]
[3] --> Logging | [Enabled]
[4] --> Filter Traffic | [all]
[5] --> Unban PrivateIP | [Enabled]
[6] --> Log Invalid Packets | [Disabled]
[7] --> Import AiProtect Data | [Enabled]
[8] --> Secure Mode | [Enabled]
[9] --> Fast Switch List | [Disabled]
[10] --> Syslog Location | [Default]
[11] --> IOT Blocking | [Disabled]
[12] --> Stats Country Lookup | [Enabled]
[13] --> CDN Whitelisting | [Enabled]
[14] --> Display WebUI | [Enabled]
[1-14]:
Above, the prompt is [1-14] but there is no way to select something that does not make any change.
Select Menu Option:
[1] --> Unban
[2] --> Ban
[4] --> Whitelist
[7] --> Save
[11] --> Settings
[13] --> Stats
[15] --> Uninstall
[r] --> Reload Menu
[e] --> Exit Menu
[1-15]: 11
[1-14]:
Hi smallnet,
Simply enter e (for Exit) to go back to Skynet's Select Menu Option.
