Skynet Skynet + Scribe Question
AppleBag
I installed Scribe, and then installed Skynet after.
Reading the Scribe installer it says its best to install Scribe after skynet; should I reinstall Scribe now, or just leave it alone? How do I know if I should reinstall Scribe (does something get screwed up, visibly or otherwise?
Also, if I do have to reinstall Scribe, will I lose any stats?
Just reinstall scribe, it will pickup the Skynet parameters. Leave Skynet as is.
The key step in making them work together is specifying in skynet the custom syslog.log location. You can see it in skynet.cfg on the Entware drive.
