dozolee
Dear all,
I'm trying to solve my problem with my Asus 4G-AC68U. I use this router in mesh with another RT-AC68U. The problem is with my Master 4G-AC68U. The LAN download speed is much lower then the download speed with wifi. I found a lot of threads in the internet with the same issue. There seems to be no solution, people are trying hard to change settings without results. I am doing the same. I've tried many cables, many Laptops, factory reset, and many firmware. I measure the download speed with speedtest.net. When I measure with my smartphone I have up to 120 Mbps and when I measure with any computer with LAN connection I can measure only 5 or 10 Mbps. I have gigabit connection on the PC. On the router Nat acceleration and Jumbo frame are enabled, QoS is disabled, and I've disabled the firewall. I've tried only one router (Master) as well. Nothing changed. It is intresting, that the master and node routers are connected with cable. My smartphone is connected to the node. I measure 120 Mbps. So the download speed between the routers with cable is fine. When I measure the speed with any of my Laptops with LAN connection the download speed is slow. How can this be possible? And another interesting thing: the upload speed is always good (30 Mbps), no matter if I use wifi or LAN.
I like to try Merlin firmware as well. Problem is that for the 4G router there is no Merlin, only for the RT. Is it possible to try one Merlin and one Asus firmware in mesh?
Thank You.
Thank You.
