I purchased both a set of Actiontec Moca 2.0 and goCoax MoCA 2.5 adapters. I was under the impression that near gigabit speeds and low latency would be easily attainable with either of these products. However, I have not been able to get any where near those speeds, and I ran out of ideas on why this is occurring. I first tried to add them into my existing network setup but was unsatisfied with the speeds. I replaced what I pretty sure is the only splitter in the coax wiring with a 5-2500 MHz splitter, but that did not improve the performance. Using iPerf3 I was getting 270Mbps with the Actiontec and 300Mbps with the goCoax. I went into trouble shooting mode and have tried everything I can think of. I stripped my network down to just my modem, router, my desktop, and my laptop. Here are the following test I ran.
1. Plugged my laptop and desktop into the router via Ethernet. Ran iPerf3 and got 920Mbps. Reran test to make sure all 3 Ethernet cords I would be using in tests were capable of passing gigabit speeds.
2. Added the Actiontec MoCa 2.0 adapter set in between my laptop and my desktop. Ran iPerf 3 and got 380 Mbps. I tried both the 3ft coax cable that came with the adapter and a 6ft coax cable I had lying around. The speeds did not change.
3. Switch out the Actiontec adapters for the goCoax MoCa 2.5 adapters. Ran iPerf 3 and got 300 Mbps. I again tried both the 3ft and 6ft coax.
Does anyone have any suggestions? I'm out of ideas. Thanks.
