MoInSTL
I have a RT-AX86U with an unusual problem. Running Merlin version 3004.388.7. I have AT&T 500mbbps fiber connection that is over provisioned to around 625 on speednet.net. The problem is my PS5. With a cat 6 cable I am getting 68mbps. If I set it up to use 5ghz I get the sane results. I followed all the instructions on the Asus site and did a hard reset. All I had to do was change the channels from auto to 11 & 44 respectively after setting up two SSIDs. I have tried everything I can think of. I ordered and installed new cat6 cables On the PS5 side I have forget network, rebooted and create a new connection several times. For 5ghz connection I enabled 5ghz only. I have left it unplugged, gone in to safe mode to clear cache and rebuild data base. I never use rest mode. I have plenty of space as I added an M.2 SSD. I know the cable is good because because my laptop was able to connect with good speed.
Here's where it gets weird: I have a BGW320 gateway (combo modem/router). There is an option to disable the WIFI and put it into passthrough mode So after pulling my hair out I plugged the same cable connected to the PS5 using an open port on the BGW320 (nothing it plugged into any of the ports) I was able to get 325mbps which is fine considering the 68mbps.. I looked and I bought the router exactly 2 years ago. I have old Asus routers that I retired and never because of problems. I think my AX86U is about dead and need confirmation. FWIW, made sure QoS was off.
