The details of my problem are as follows:
1- My GT-AC5300's WAN port is connected via a CAT 6 cable to another router’s LAN port (LinkSys WRT32x)
2- The WAN LED on my GT-AC5300 is white (Indicating a successful WAN connection)
3- My Gaming PC is connected to the GT-AC5300 using LAN port 1 using a CAT 6 cable
4- My Internet speed is fast on the LinkSys WRT32x (~100 Mbps down, and ~30 Mbps up). On the GT-AC5300 however, it's slow most of the time (4-10 Mbps), and the only thing that fixes it is if I unplug/replug the CAT 6 cable connected to the WAN port repeatedly before it works well again.
Additional Details:
1- My GT-AC5300 router is configured with a static IP so it can connect to LinkSys WRT32x. The static configuration is as follows:
2- There is no IP conflict on my network
3- If I ping the LinkSys WRT32x router (Acting like the gateway), I get Request Timed Out every ~10 successful pings
4- The WAN port’s pins look good
Things I tried:
1- Restoring the router to factory settings
2- Reflashing the firmware with the latest firmware build 3.0.0.4.386_42643-g16dc577 (I also tested all the older firmwares for the router)
3- Tried to connect the GT-AC5300's WAN port to another router (My Asus 4G-AC68U)
4- Different Cat 6 cables
5- Tested the Internet on a laptop that's connected to a different LAN port on GT-AC5300
6- Tested the Internet using my phone over Wi-Fi
Not only that, even the Admin Consoles of the different routers that I tried to connect to my GT-AC5300's WAN port were either timing out, or painfully slow to navigate. The only thing that would fix my problem is if I unplug/replug the CAT 6 cable from my WAN port many many many times.
The System log shows the following when the problem is happening:
When the problem happens, I can see the following in the System Log:
When the problem is fixed (By unplugging/replugging the Cat 6 cable to the WAN port many many many times), I stop seeing the above logs.
I contacted Asus’ customer support, and the only replies I got from them are some generic messages asking me to reflash the firmware, although I had already mentioned to them that I’ve already done that.
Please help.
Additional Details:
IP Address: 192.168.1.229
Subnet Mask: 255.255.255.0
Gateway Address: 192.168.1.1 (Same as the IPv4 LAN address of the WRT32x)
Primary DNS: 192.168.1.1 (Same as the IPv4 LAN address of the WRT32x)
Secondary DNS: 8.8.8.8
Things I tried:
Nov 20 19:45:35 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:45:41 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:02 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:07 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:10 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:11 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:13 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:19 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Nov 20 19:46:20 kernel: FPM Pool 0: invalid token 0x003ff000 freed
Please help.
