Hi All, I have done a lot of testing on how to improve the VPN speeds over wireguard. Observation is that on every single reboot, the VPN will connect automatically as designed, however the speeds will be exactly limited to 150 Mbps. I have to manual disconnect and reconnect to get over 800 Mbps of speed. This is over a wired connection. Similar observation is over wireless as well. I believe there is some kind of a bug in the router. I have done a factory reset with the downgrade option to see if this issue goes away.
Has anyone else experienced this issue?
