I'm shooting myself for not checking this way back when when I started this thread https://www.snbforums.com/threads/smart-connect-rules-apply-button-not-working.34406/
But I found my issue in that thread with poor throughput on 2.4Ghz was simply solved by using Channel 1 instead of Channel 6 that Auto was selecting.
So, now, I want to still use Smart Connect as I've got it working pretty well for 5 vs 2.4Ghz selection, however, when I enable it I get forced to use the Auto control channel selection which always uses channel 6 whereas I want to force it to use channel 1!
@RMerlin - any chance you can see if this is a superficial GUI change to allow setting of channel with Smart Connect enabled, or if it is more involved are you willing to go digging!? Extra beer tokens coming your way if you can make it work
Many Thanks
Many Thanks
