Yes I have one Amazon echo and 2 Amazon dots networked on 5Ghz. I would like to turn a light on and off in my home instead of using a manual timer. I guess I will have to run 2.4Ghz again after many years with it being turned off. I am thinking of using our 4th gen AppleTV with HomeKit. It runs all the time and I don't have to run a server. I am a real novice at this stuff.
What is the difference in using a power plug or light bulb for turning on and off a light?
Other IoT devices still mainly use 2.4Ghz for several reasons:
1. The chips are cheaper.
2. Most IoT devices don't use much data and/or need much bandwidth. For instance my garage door controller has only used 14.8 KB of data so far in September.
3. 2.4 Ghz radios have better range and penetration power.
Thread starter | Title | Forum | Replies | Date |
D | Tuya Smart Home video doorbell WiFi issue | General Smart Home Discussion | 0 | |
Security Cams for Home (NEST ?) | General Smart Home Discussion | 2 | ||
S | Home Automation question | General Smart Home Discussion | 3 |
Welcome To SNBForums
