Skoven
Hi.
I am trying to use smart sync, but it will not work
I have tried with samba and a ftp-server on my MacBook: i am able to connect to my MacBook, from my PC just fine (both samba and ftp works), but nothing happens when i try to use smart sync (the ftp log show successful login, when trying ftp-sync from the router, so the connection should be fine).
Samba just hangs at "INITIAL" (mouse over "verifying") and ftp shows "Finish" (mouse over "sync has been completed"). Nothing is synced though.
Also tried inputting the IP - same result.
Anyone having success with smart sync? Perhaps it is not working in "newer" firmware versions?
I am on 380.59 merlin firmware.
