Solved SMB problem with new router
maghuro
On my old RT-AC86U, I had a script that mounted a folder of my QNAP on router, and then rsync between that QNAP folder and another folder in the router. Everything worked flawlessly.
I switch today to GT-AX6000, copy pasted the entire script (none have changed, neither credentials of qnap), and it didn't work.
The command being used is:
Bash:
mount \\\\qnap.domain\\Backups\\GT-AX6000 /tmp/mnt/QNAP230 -t cifs -o "username=USER,password=PASS" -o vers=3.0
On the GT-AX6000, the output is:
mount: mounting \\qnap.domain\Backups\GT-AX6000 on /tmp/mnt/QNAP230 failed: Permission denied
I double checked login and password, I searched the web, no success. I installed mount-utils and tried, the result was different but no success:
mount: /tmp/mnt/QNAP230: bad option; for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount.<type> helper program.
Can someone help me to figure out what am I doing wrong?
Edit: solution, see post #9
Remove the mount-utils package as it will conflict with the router's built-in commands.
Do you have Samba enabled on the router?
Removed.
Samba server disabled. I tried to enable it, for sake of testing, and same error.
Leave the Samba server enabled and sharing something. Then reboot the router and try again.
Strange. Might be a regression bug in the 388.x firmware. Try using vers=2.1 or vers=2.0 instead.
The latest builds are missing a kernel module. @RMerlin commented on the same issue in another thread. I am trying to find the post/kernel module at the moment. The module is in the /lib directory somewhere, I just need to to remember what it is.......
I had the same exact issue. Moving from an AX88U (fw 386) to AX88U Pro (fw 388).
As @Jeffrey Young said, simply add:
/sbin/modprobe md4
As the first line in your /jffs/scripts/services-start file.
