Laxarus
Hello guys,
I wonder if any of you are having the same problem.
384.19 with rt-ac5300.
When you enable Samba whereas on windows, you don't enable deprecated SMBv1 support, you stop seeing network devices on "My Network Places".
The logic here is like this. You enable Samba and even if you don't enable master browser, when no windows machines are present, router automatically becomes master browser. When it becomes "Master", even if I select SMBv2 as minimum protocol, the "WORKGROUP" machines(Especially NAS devices) is still not visible from windows machine.
Restarting the router temporarily makes the windows machine as "Master" and makes "WORKGROUP" visible. However, when you shut down the windows machine, the router becomes Master again.
There are couple of options here to fix the issue to a certain degree.
- Disable SAMBA on the router.
- Change the domain of the router from "WORKGROUP" to something else. (In theory, this should work but didn't try yet.)
- Use a dedicated windows server machine.
- Enable SMBv1 on the windows machines.
These are all the options I could test to make things work again but they are not satisfactory
first method loses the functinality.
second method loses the visibility
third method is ridicilous.
fourth method is not safe and a lot of work if you have lots of machines. (Not to mention windows turns it off arbitrarily when updated.)
Am I missing something here? Do you guys also have the same problem or this is a specific problem for my network? Is there a definite fix for this?
