EastCoastMaster
Well, I've been a fan of this website for a long time so I decided to join the forum - This is my first post, yay. Anyway, I'm just curious if the "Saberlink" Cat6 cable from my local home depot is any good for wiring my new house? My father's a building contractor and he is building the house I'm buying so luckily I have the opportunity to run Cat6 right after it's been framed and the electrician is running power, cable and Cat5e for phone lines - (might convince him to use Cat6 for future proofing).
Anyway the cable says it's made in the USA and it's definitely real copper, not that copper-clad shiz, and it's rated for in-wall. My main concern tho is how much does it effect the cable, not having a plastic center core like most Cat6 cable has because I know it supposed to help further prevent alien crosstalk, especially at high frequencies?
The reason I'm concerned isn't so much for my gigabit network I plan to be running off of a Netgear 16 & 5 port switch, it's for the future, say 5 years from now when a 8 port 10gbit switch off newegg costs $199 and I want to make sure the cable will be sufficient and yes I know your're limited on cable length. BTW the reason for the 5 port is because it is manageable for things like bandwidth control so I can run my Main CPU plus whichever extra pc needs the 2000mbps for backup, a 2TB WD My Book Live (a NAS technically), and an old amd athlon pc with four SATA 2 HDD's run in JBOD on windows home server or maybe freenas or possibly unraid - (still building it as of now)
