Entware [SOLUTION] Cross-Compile ProxyChains-NG Entware Package via Debian Live DVD
garycnew
NOTE: After finally being convinced by the Entware & OpenWRT Developers that neither Build Environment was meant to be Compiled Natively on a Router (Neutered C Libraries), I decided to pursue this Cross-Compile ProxyChains-NG Entware Package via Debian Live DVD solution; which, is presumably a bit slower, but ultimately successful. It wasn't too terrible after finding the right cross-compiling platform and combining a few different build references.
Requirements/Assumptions:
Cross-Compiling Host Machine:
1. Plenty of Physical Memory (RAM)
2. Debian Live (Testing) DVD
3. Flash Drive >= 32GB (Preferably USB 3.0/3.1)
ProxyChains-NG Installation Machine:
1. An Asuswrt-Merlin Compatible Router (i.e., Asus RT-AC66U)
2. Asuswrt-Merlin Compatible Firmware (i.e., 384.19)
3. Formated JFFS Partition and Enabled JFFS Custom Scripts and Configs
4. Entware installed on USB 3.0 Interface Device via Asuswrt-Merlin Terminal Menu (AMTM) with Swap File created
NOTE: Not sure if it matters... At the time of this writing, Debian Bullseye (Testing) Live DVD contained the same package versions as the current Entware repository, opposed to the Debian Buster (Stable) Live DVD, so we opted to use the Debian Bullseye (Testing) Live DVD.
### Download & Burn Debian Live (Testing) DVD ###
$ curl -L -O -C - http://cdimage.debian.org/cdimage/unofficial/non-free/cd-including-firmware/weekly-live-builds/amd64/iso-hybrid/debian-live-testing-amd64-gnome+nonfree.iso
### Boot Debian Live (Testing) DVD on the Cross-Compiling Host Machine ###
Our Cross-Compiling Host Machine required the [F12] key to be pressed during boot to enter into the Boot Menu and select the Debian Live (Testing) DVD. Make sure you setup and have Internet access on the Cross-Compiling Host Machine.
### Open Terminal ###
### Mount Flash Drive (Repeat after each DVD Boot) ###
$ sudo -p /media/user/SanDiskSDCZ
$ sudo mount /dev/sdb1 /media/user/SanDiskSDCZ
$ cd /media/user/SanDiskSDCZ/
### Download & Install Build System (Repeat after each DVD Boot) ###
$ sudo apt-get update
$ sudo apt-get install git-core build-essential libssl-dev libncurses5-dev unzip gawk zlib1g-dev
$ sudo apt-get install python2 wget
### Clone, Setup, & Make Entware Build Env ###
$ git clone https://github.com/Entware/Entware.git
$ cd Entware
# Update OpenWRT Feeds
$ ./scripts/feeds update -a
# Symlink Packages (Repeat after each DVD Boot)
$ make package/symlinks
# Copy the config specific to your Architecture and Kernel versions
$ cp configs/armv7-2.6.config .config
$ make tools/install && make toolchain/install && make target/compile
or
#$ make -j1 V=sc tools/install
#$ make -j1 V=sc toolchain/install
#$ make -j1 V=sc target/compile
### Download, Prepare, & Compile Test Package from OpenWRT Feed ###
#$ ./scripts/feeds install screen
or
$ make -j1 V=sc package/screen/download
$ make -j1 V=sc package/screen/check
$ find package/ -iname "*screen*"
package/feeds/packages/screen
$ make -j1 V=sc package/screen/prepare
$ make -j1 V=sc package/screen/compile
#$ make -j1 V=sc package/screen/install
#$ make package/index
$ find bin/ -iname "*screen*"
bin/targets/armv7-2.6/generic-glibc/packages/screen_4.8.0-2_armv7-2.6.ipk
### Download & Prepare OpenWRT Feed Package modified for Entware (When Available) ###
#$ ./scripts/feeds install proxychains-ng
or
$ make -j1 V=sc package/feeds/packages/proxychains-ng/download
$ make -j1 V=sc package/feeds/packages/proxychains-ng/check
$ find package/ -iname "*proxychains-ng*"
### Edit the Makefile to use the /opt directory prefix ###
$ diff package/feeds/packages/proxychains-ng/Makefile.orig package/feeds/packages/proxychains-ng/Makefile
49c49
< /etc/proxychains.conf
> /opt/etc/proxychains.conf
54,56c54,56
<     $(INSTALL_DIR) $(1)/usr/bin
<     $(INSTALL_BIN) $(PKG_INSTALL_DIR)/usr/bin/proxychains4 $(1)/usr/bin/
<     $(LN) proxychains4 $(1)/usr/bin/proxychains
>     $(INSTALL_DIR) $(1)/opt/bin
>     $(INSTALL_BIN) $(PKG_INSTALL_DIR)/opt/bin/proxychains4 $(1)/opt/bin/
>     $(LN) proxychains4 $(1)/opt/bin/proxychains
59,60c59,60
<     $(INSTALL_DIR) $(1)/usr/lib
<     $(INSTALL_DATA) $(PKG_INSTALL_DIR)/usr/lib/libproxychains4.so $(1)/usr/lib/
>     $(INSTALL_DIR) $(1)/opt/lib
>     $(INSTALL_DATA) $(PKG_INSTALL_DIR)/opt/lib/libproxychains4.so $(1)/opt/lib/
63,64c63,64
<     $(INSTALL_DIR) $(1)/etc
<     $(INSTALL_DATA) $(PKG_INSTALL_DIR)/etc/proxychains.conf $(1)/etc/
>     $(INSTALL_DIR) $(1)/opt/etc
>     $(INSTALL_DATA) $(PKG_INSTALL_DIR)/opt/etc/proxychains.conf $(1)/opt/etc/
### Select proxychains-ng for [M]odular inclusion under the SECTION => CATEGORY => SUBMENU of menuconfig ###
$ make menuconfig
define Package/proxychains-ng
SECTION:=net
CATEGORY:=Network
TITLE:=Redirect TCP traffic to a HTTP or SOCKS proxy
URL:=https://github.com/rofl0r/proxychains/
endef
### Compile OpenWRT Feed Package modified for Entware ###
$ make -j1 V=sc package/feeds/packages/proxychains-ng/prepare
$ make -j1 V=sc package/feeds/packages/proxychains-ng/compile
#$ make -j1 V=sc package/feeds/packages/proxychains-ng/install
$ find bin/ -iname "*proxychains-ng*"
bin/targets/armv7-2.6/generic-glibc/packages/proxychains-ng_4.15-1_armv7-2.6.ipk
### SFTP & SSH proxychains-ng Package to ProxyChains-NG Installation Machine(s) ###
$ cd bin/targets/armv7-2.6/generic-glibc/packages/
$ sftp admin@192.168.0.1
sftp> cd /tmp/mnt/SanDiskSDHC/
sftp> put proxychains-ng_4.15-1_armv7-2.6.ipk
$ ssh admin@192.168.0.1
# cd /tmp/mnt/SanDiskSDHC/
# opkg install ./proxychains-ng_4.15-1_armv7-2.6.ipk
# opkg list-installed|grep -i proxychains
proxychains-ng - 4.15-1
# opkg files proxychains-ng
Package proxychains-ng (4.15-1) is installed on root and has the following files:
# opkg info proxychains-ng
Package: proxychains-ng
Version: 4.15-1
Depends: libc, libssp, librt, libpthread
Status: install user installed
Architecture: armv7-2.6
Conffiles:
/opt/etc/proxychains.conf abeab0c91cbf2f8a3c87a45059a1c939d027fbd51d43df14e8dc1652da0f535b
Installed-Time: 1642910684
# /opt/bin/proxychains4
Usage:    /opt/bin/proxychains4 -q -f config_file program_name [arguments]
    -q makes proxychains quiet - this overrides the config setting
    -f allows one to manually specify a configfile to use
    for example : proxychains telnet somehost.com
More help in README file
# /opt/bin/proxychains4 wget -O - https://ifconfig.me
or
# LD_PRELOAD=/opt/lib/libproxychains4.so wget -O - https://ifconfig.me
Congratulations! You've Cross-Compiled a ProxyChains-NG Entware Package via Debian Live (Testing) DVD! The Possibilities are Endless with Good-Times Ahead!
References:
http://bin.entware.net/armv7sf-k2.6/
https://packages.debian.org/search?keywords=search
https://oldwiki.archive.openwrt.org/about/toolchain
https://oldwiki.archive.openwrt.org/doc/howto/buildroot.exigence
https://oldwiki.archive.openwrt.org/doc/howto/build.a.package
https://github.com/Entware/Entware/wiki/How-to-add-a-new-package
https://github.com/Entware/Entware-ng/wiki/Using-gcc-%28native-compilation%29
https://github.com/rofl0r/proxychains-ng
https://github.com/amezin/openwrt-packages/blob/master/net/proxychains-ng/Makefile
### Full Edited proxychains-ng Makefile ###
$ cat feeds/packages/net/proxychains-ng/Makefile
# Copyright (C) 2019-2021 Daniel Bermond
# This is free software, licensed under the GNU General Public License v2.
# See /LICENSE for more information.
include $(TOPDIR)/rules.mk
PKG_NAME:=proxychains-ng
PKG_VERSION:=4.15
PKG_RELEASE:=1
PKG_SOURCE:=$(PKG_NAME)-$(PKG_VERSION).tar.gz
PKG_SOURCE_URL:=https://codeload.github.com/rofl0r/proxychains-ng/tar.gz/v$(PKG_VERSION)?
PKG_HASH:=c94edded38baa0447766f6e5d0ec1963bb27c7b55b2a78b305d6f58e171388f8
PKG_MAINTAINER:=Daniel Bermond <dbermond@archlinux.org>
PKG_LICENSE:=GPL-2.0-or-later
PKG_LICENSE_FILES:=COPYING
PKG_BUILD_PARALLEL:=1
PKG_INSTALL:=1
include $(INCLUDE_DIR)/package.mk
  SECTION:=net
  CATEGORY:=Network
endef
define Package/proxychains-ng/description
  A hook preloader that allows to redirect TCP traffic of
  existing dynamically linked programs through one or more
  SOCKS or HTTP proxies.
endef
define Build/Compile
    $(call Build/Compile/Default,all)
endef
define Build/Install
    $(call Build/Install/Default,install install-config)
endef
define Package/proxychains-ng/conffiles
endef
define Package/proxychains-ng/install
    # binary executable
    # library
    # config
endef
$(eval $(call BuildPackage,proxychains-ng))
  • proxychains-ng_4.15-1_armv7-2.6.txt
$ cd Entware
or
or
or
49c49
54,56c54,56
59,60c59,60
63,64c63,64
$ make menuconfig
SECTION:=net
CATEGORY:=Network
endef
Version: 4.15-1
Conffiles:
or
References:
PKG_VERSION:=4.15
PKG_RELEASE:=1
PKG_INSTALL:=1
  SECTION:=net
  CATEGORY:=Network
endef
endef
endef
endef
endef
    # binary executable
    # library
    # config
endef
I might have to take a stab at this. Thanks for your consistent dedication for compiling. :D
I've discovered that proxychains-ng works very well with Tor and is a better replacement to torsocks in some implementations. Enjoy! ;)
I tried to compile it for RT-AC68U by changing target to aarch64 but when I run proxychain I get this error
admin@RT-AC86U-1DE0:/tmp/home/root# proxychains4 curl ifconfig.me
[proxychains] config file found: /opt/etc/proxychains.conf
[proxychains] preloading /opt/lib/libproxychains4.so
ERROR: ld.so: object '/opt/lib/libproxychains4.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
You mean to armv7 correct?
I tried the armv7 target but the resulting ipk is not installable
admin@RT-AC86U-1DE0:/tmp/mnt/asus-ext4/entware/tmp# opkg install proxychains-ng_4.16-1_armv7-3.2.ipk
Unknown package 'proxychains-ng'.
Collected errors:
 * pkg_hash_fetch_best_installation_candidate: Packages for proxychains-ng found, but incompatible with the architectures configured
 * opkg_install_cmd: Cannot install package proxychains-ng.
the binary also appears to be looking for the interpreter in the wrong directory, ld-linux.so.3 is located in /lib
admin@RT-AC86U-1DE0:/tmp/mnt/asus-ext4/entware/tmp# patchelf --print-interpreter proxychains
/opt/lib/ld-linux.so.3
proxychains compiled with the armv7 target work but I couldn't get a binary that uses /lib/ld-linux.so.3 as the interpreter instead of /opt/lib/ld-linux.so.3 and obviously I can't install it via ipk produced but only using the binary files directly after creating a symbolic link to /opt/lib/ld-linux.so.3
Collected errors:
@70mmy
Did you edit the proxychains-ng/Makefile to use /lib instead of /opt/lib path?
Change From:
# library
Change To:
# library
$(INSTALL_DIR) $(1)/lib
$(INSTALL_DATA) $(PKG_INSTALL_DIR)/lib/libproxychains4.so $(1)/lib/
Kind Regards,
Gary
Not sure what problem you're trying to solve...
The various toolchains/sdk's are there for a reason, and they generate optimized code for the platforms...
@sfx2000
At the time of the original posting, proxychains-ng wasn't available for the architecture and kernel version in which I needed it. So... I decided to roll my own and created this posting from my notes.
Entware uses a modified OpenWRT packaging process that requires slight modification to the Makefile paths.
I hope that answers your question.
Kind Regards,
Gary
proxychains-ns seem to be still unavailable today either on entware and I'm looking for the easiest way to get a working binary for the rt-ac86u
@70mmy
Change From:
Change To:
Kind Regards,
Gary
making this change will make /opt/lib/libproxychains4.so installed in /lib ? ... anyway i fixed using patchelf --set-interpreter /lib/ld-linux.so.3 /opt/bin/proxychains, if I really wanted to do things properly I would have to find a way to package everything in an ipk file
Correct. The Makefile modification would only change where the libproxychains4.so is installed.
My ld-linux.so.3 is installed under /opt on my Asuswrt:
# find /opt/ -iname "*ld-linux*"
Do you have Entware installed under the default location (/opt)?
Kind Regards,
Gary
Entware is installed under default location
admin@RT-AC86U-1DE0:/tmp/home/root# ls /opt/lib/ld*
/opt/lib/ld-2.27.so             /opt/lib/ld-linux-aarch64.so.1
Then, you shouldn't need to modify the Makefile.
Did you copy the configs/aarch64-#.#.config to .config? Where #.#.config is the kernel version.
$ cd Entware
That should setup the config variables for the specific compilation environment.
Regards,
Gary
Just a thought: You could setup a custom Entware repository using GitHub workflow like this so others can just add the repository to their opkg.conf instead of compiling manually
@jacklul
The issue is that there are a number of different architecture and kernel versions that the process supports and it often differs per person.
Case in point... My needs are for armv7-2.6; while @70mmy are for aarch64-some.kernel.
I thought it would be more helpful to provide guidance on rolling your own.
I appreciate the thought, though.
Respectfully,
Gary
It supports building using all Entware's build targets, I am using it to build packages for supported architectures in my repository
It is a matter of convenience, some may want to build themselves anyway while others just need ready to use package
@jacklul
You opt to build the package for all targets (architectures and kernels) and provide them as a repo?
Gary
I'd prefer not to put a package in my repo that I can't provide support for
@jacklul
The previous question was about your packaging process not whether you would include proxychains-ng in your repo.
Respectfully,
Gary
