dreadnought
VPNs on my ASUS routers running Merlin firmware work great... over time though I have noticed the streaming services like Amazon and Netflix getting more hostile to (or, just more effective at blocking) VPN providers.
Other than constantly disabling the router-to-router VPNs to satisfy Amazon, Netflix, and others (not happening!), I'm looking for advice on the best way to continue using the VPNs but also use the streaming services.
Is it possible on the RT-AC87U with Merlin's firmware to have an OVPN tunnel on one radio and no OVPN tunnel on the other radio? So for example, all the devices that need to use streaming services would connect to the 5ghz radio that does not have an OVPN tunnel configured?
Or, is getting a cheap access point only for streaming services (so no OVPN tunnel) to put in parallel with the RT-AC87U a better idea?
Thanks!
Thanks!
