[SOLVED] 378.50+ not running post-mount script
Vinicius Cordeiro
After update to 378.50+ and did a factory reset, installed entware again, etc, now the router is not running /jffs/scripts/post-mount, then every boot I need to manually create entware link to /opt
admin@RT-AC66R:/jffs/scripts# ls -la
drwxr-xr-x    2 admin    root             0 Mar  1 23:51 .
drwxr-xr-x    5 admin    root             0 Dec 31  1969 ..
-rwxrwxrwx    1 admin    root            80 Mar  1 23:51 post-mount
-rwxrwxrwx    1 admin    root            53 Mar  1 23:51 services-start
-rwxrwxrwx    1 admin    root            43 Mar  1 23:51 services-stop
admin@RT-AC66R:/jffs/scripts# cat post-mount
#!/bin/sh
if [ $1 = "/tmp/mnt/RT-AC66R" ]
then
  ln -sf $1/entware /tmp/opt
fi
Did you enable the option "Enable JFFS custom scripts and configs" under Administration/System? :rolleyes:
This new since .50 version of Merlins firmware.
With kind regards
Joe :cool:
Just a small comment.
I notice that your file permissions for the scripts are
-rwxrwxrwx
The last set rwx allows world write, which would allow a hacker if they gained access to your device via a hole in dnsmasq (running as nobody) to change the script. From a security point, this is wrong.
Since these scripts are always run by admin, you should change the permissions to the minimum required with
chmod 700 /jffs/scripts/*
With kind regards
Joe :cool:
Hi @joegreat
Thank you so much!!! You're right! That option was not present before 378.50 versions, now everything is ok!
-rwxrwxrwx
Hi @coldwizard
I didn't change this and probably is default on firmware, but I'm changing it right now!
