amplatfus
Hi dear RT-AX88U owners,
Could you please help me to find out if RT-AX88U have GMAC3 or not?
I have GMAC3 on RT-AC88U and it is set a limit to me when enable some etables rules in firewall.
For instance if I want to drop 2.4Ghz and 5 Ghz traffic to one IP, only the rule with 2.4Ghz is working. The rule with 5 Ghz is working only if I disable GMAC3.
But what GMAC3 is doing is not very clear, and I am not very sure about the impact in performance and in product lifetime when is disabled.
And in the far future maybe I will step to the RT-AX88U.
From what I have read here on SNB Forums it seems that "gmac3 changes the internal switch configuration and CPU communication port/VLAN definitions.".
This check can be done by doing like here below on RT-AC88U where GMAC3 is present and is turned on by default:
The result is 1. If you could please let me know on RT-AX88U what is your output, I would appreciate very much.
Thank you very much in advance,
amplatfus
router@asus:/tmp/home/root# nvram get gmac3_enable
1
amplatfus
