[SOLVED] Guest Network
hw1380
I was switching from Tomato to ASUS-WRT firmware recently and erything is working fine so far.
Router: RT-AC68
Firmware version: 380.58
After creating a guest network, I realized that there is no switch to enable or disable the guest network which I have just created.
That said, I have to create the guest network if a guest wants to join and remove the guest network if the guest leaves. This is quite uncomfortable.
Is this feature not implemented or did I miss something ?
Go back to the Guest Network page, and click on "Remove". If later on you click again on "Enable", it will have remembered your previous parameters.
Hi RMerlin,
thanks for your quick response.
I was able to re-activate the guest network.
Side effect was that both wifi networks got briefly interrupted.
I have marked this thread as solved.
