Spydawg
If I enable QOS (Default or FreshJR's) I can't seem to get to some Websites for example www.dslreports.com
I'm running a ASUS RT-AC3100 Firmware Version: 384.4_2
My Connection is Fiber 350 down 100 up.
I have done a factory reset and Initialize plus Format JFFS partition.
This all started after I upgraded my firmware from 384.3_0, all seemed ok..
2 days later my Lexar USB Key Died that was in the router that had AB-solution, pixelserver.tls , and FreshJR's
QOS script.
Replaced it with a Kingston DT50 3.1 USB Key and been having issues since. Tried with a few more USB Keys I
had, thinking it could be the problem. But issues remain.
I also just noticed if I enable the AiProtection it gives me the same issues with the same web pages.
I'm at a loss.
Any ideas?
QOS script.
I'm at a loss.
Any ideas?
