Dear Forum,
Around the time of the install of 386_6 on my AC86U and subsequent reboot, grep broke on my system. I cannot invoke it in the shell, nor can scripts use it. (I can infer the timing of the issue thanks to the connmon script that started failing.)
After first install of 386_6 (and a few reboots), whenever grep is invoked:
relocation error: /opt/lib/libgcc_s.so.1: symbol memcpy@_Unwind_Ge�FR version GLIBC_2.17 not defined in file libc.so.6 with link time reference
(NB: Notice the funky character appearing right before FR near the middle of the line above. It was also visible in the shell.)
This issue seems similar to https://www.snbforums.com/threads/s...-defined-in-file-libc-so-6.70099/#post-661069
In that thread, the solution was to remove the failing package with opkg remove. In my case, I think that I cannot remove grep because there is no other grep on our systems (at least when I rename the file grep to grep_XXX, I can't invoke grep and get the expected grep functionality).
After second install of 386_6, I got messages like:
XXXXXX@AC86:/tmp/home/root# grep
Inconsistency detected by ld.so: get-dynamic-info.h: 124: elf_get_dynamic_info: Assertion `info[DT_PLTREL]->d_un.d_val == DT_RELA' failed!
I get the same sort of messages with "column" (which is another utility, like grep, which I didn't know). I guess the same solution (if any) might apply to column but it's fishy I get both issues...
I tryed to reinstal grep, with opkg install grep --force-reinstall:
but I still get the same "Inconsistency detected" message.
Any specific ideas ? (beyond nuking it ;-)
Thank you very much in advance
Take care
W.
XXX@AC86:/tmp/home/root# opkg install grep --force-reinstall
Removing package grep from root...
Installing grep (3.6-1a) to root...
Downloading http://bin.entware.net/aarch64-k3.10/grep_3.6-1a_aarch64-3.10.ipk
Configuring grep.
Take care
W.
