Netbug
Ok not sure what to do to check for anything suspicious. using latest merlin firmware 384.4_2 factory reset/fresh install when 384.4_2 was released.
Turned my WiFi on phone and auto connected to my network like normal, then norton mobile app pops up saying my wifi is compromised. This network is compromised by an unknown third party that may view and alter your communications.
Then it says...
SSL Decrypting, An attacker is attempting to decrypt this entowrk and may view and alter your communications.
As you can imagine i found it to be very alarming, Anyone have any suggestions? i have looked in logs i see nothing that indicates anything odd, checked client list, dhcp releases, connections, routing table, portforwarding, run 'top' command in terminal incase something suspicious was running all looks ok, just to ensure nothing odd going on and find nothing to suggest someone may have hacked my network or gained access or is trying to decrypt traffic, i do have wire shark on my macbook but not used it in ages. I'm worried now and looking for suggestions.
Thank you.
Update:
Issue was with the Norton app tut tut.
[Solved] Norton Mobile claiming my wifi network is compromised?
Then it says...
Thank you.
Update:
