[SOLVED] Openvpn listen on ip
mad_ady
Currently openvpn binds all interfaces when listening on a port:
tcp        0      0 :::443                  :::*                    LISTEN      967/vpnserver1
I'd like to start the server and have it listen on a specific IP (ppp0). The purpose is I want to run openvpn on 443 on the external interface and pixelserv-tls on 443 on a internal interface. I know I can use the "listen 1.2.3.4" configuration option, but:
1. /etc/openvpn/* seems to be generated on the fly on server startup. Is there a startup script I can modify to do my own thing? (find the ip on ppp0 and write it in the config before server startup)
2. I think that the server isn't restarted when an interface/ip gets reconfigured. The socket API handles it transparently when bound to 0.0.0.0. I will probably need to do manual restarts on wan changes, right?
Thanks!
Create openvpnserver1.postconf and modify the config.
That's a shellscript, right? And is executed before server startup I take it?
Thanks, will do that
Yes.
Here is a template for OpenVPN server #1
/jffs/scripts/openvpnserver1.postconf
#!/bin/sh
CONFIG=$1
VPN_ID=$(echo $(basename $0) | grep -oE "[1-2]")
source /usr/sbin/helper.sh
logger -st "($(basename $0))" $$ $VER "Started....." [$@]
# Do custom 'config.ovpn' stuff here....
# e.g.
#logger -st "($(basename $0))" $$ "Replace 'verb 3' with 'verb 9'"
#pc_replace "verb 3" "verb 9" $CONFIG
#logger -st "($(basename $0))" $$ "Delete 'duplicate-cn'"
#pc_delete "duplicate-cn" $CONFIG
#push_lan_metric=100
#/bin/sed -r -i 's/(^push .* vpn_gateway ).*(")/\1'${push_lan_metric}'\2/' "$1"
echo -e "#\n# '$0' Edited this file!" >> $CONFIG
logger -st "($(basename $0))" $$ "Complete."
exit 0
see Wiki Custom-config-files for help on the 'pc_xxxxxx' helper functions
It seems that listen doesn't work when used with the ddns name, sadly:
Mar  4 22:02:46 openvpn[10356]: Options error: Unrecognized option or missing or extra parameter(s) in config.ovpn:28: listen (2.4.3)
Mar  4 22:02:46 openvpn[10356]: Use --help for more information.
Mar  4 22:02:46 syslog: VPN_LOG_ERROR: 1539: Starting VPN instance failed...
I will try with the post config script and let you know.
Yes, local ddns-name worked beautifully. Thank you! Does openvpn need to be restarted manually on wan up/down or does it restart automatically? I will test as soon as possible.
I suspect that if your WAN IP changes, your server will no longer be listening to the correct IP.
That's what I suspected. This is my attempted fix in /jffs/scripts/wan-start:
#!/bin/sh
#allow ppp0 to start
sleep 10
#restart openvpn server1 to allow it to listen to the correct IP
service stop_vpnserver1
sleep 4
service start_vpnserver1
We'll see how it goes, thanks!
