mad4merlin
Hi...
I have one client PC (IP: 10.0.0.11) using the router (IP: 10.0.0.1) and I want to force it to use VPN or have no internet access otherwise. The problem is that client can still access the internet when the tunnel is down! It is like the settings have no effect at all!
I searched and tried but I don't know how to fix this, can someone pls help?
My config:
RT-N66R Merlin 380.63_2
Parent controls: OFF
VPN Client 1,
TUN, UDP,
Redirect Internet Traffic: Policy Rules,
Block routed clients if tunnel goes down: Yes,
Rules for routing ....
All2VPN 10.0.0.0/24 0.0.0.0 VPN
Administration:
Allow SSH: LAN+WAN
Allow SSH port forwarding: Yes
openvpn-routing log lines:
With the tunnel connected, here is my "iptables -vL" output:
and my "route" output is:
My config:
VPN Client 1,
TUN, UDP,
Administration:
Allow SSH: LAN+WAN
Dec 12 18:50:33 openvpn-routing: Configuring policy rules for client 1
Dec 12 18:50:33 openvpn-routing: Creating VPN routing table
Dec 12 18:50:33 openvpn-routing: Removing route for 0.0.0.0/1 to tun11 from main routing table
Dec 12 18:50:33 openvpn-routing: Removing route for 128.0.0.0/1 to tun11 from main routing table
Dec 12 18:50:33 openvpn-routing: Removing rule 10101 from routing policy
Dec 12 18:50:33 openvpn-routing: Adding route for 10.0.0.0/24 to 0.0.0.0 through VPN client 1
Dec 12 18:50:33 openvpn-routing: Tunnel re-established, restoring WAN access to clients
Dec 12 18:50:33 openvpn-routing: Completed routing policy configuration for client 1
admin@RT-N66R:/tmp/home/root# iptables -vL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
8 964 ACCEPT all -- tun11 any anywhere anywhere
0 0 DROP icmp -- eth0 any anywhere anywhere icmp echo-request
2540 215K ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED
0 0 DROP all -- any any anywhere anywhere state INVALID
51 8561 ACCEPT all -- br0 any anywhere anywhere state NEW
45 8597 ACCEPT all -- lo any anywhere anywhere state NEW
105 6720 ACCEPT tcp -- any any anywhere router.asus.com ctstate DNAT tcp dpt:www
2 180 SSHBFP tcp -- eth0 any anywhere anywhere tcp dpt:ssh state NEW
0 0 ACCEPT icmp -- any any anywhere anywhere icmp !echo-request
40 2723 DROP all -- any any anywhere anywhere
Chain FORWARD (policy DROP 0 packets, 0 bytes)
3 400 ACCEPT all -- any any anywhere anywhere state RELATED,ESTABLISHED
0 0 ACCEPT all -- tun11 any anywhere anywhere
0 0 DROP all -- !br0 eth0 anywhere anywhere
0 0 DROP all -- eth0 any anywhere anywhere state INVALID
0 0 ACCEPT all -- br0 br0 anywhere anywhere
0 0 ACCEPT all -- any any anywhere anywhere ctstate DNAT
2 1509 ACCEPT all -- br0 any anywhere anywhere
Chain OUTPUT (policy ACCEPT 3223 packets, 3313K bytes)
Chain FUPNP (0 references)
Chain NSFW (0 references)
Chain PControls (0 references)
Chain SECURITY (0 references)
0 0 RETURN tcp -- any any anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
0 0 DROP tcp -- any any anywhere anywhere tcp flags:FIN,SYN,RST,ACK/SYN
0 0 RETURN tcp -- any any anywhere anywhere tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
0 0 DROP tcp -- any any anywhere anywhere tcp flags:FIN,SYN,RST,ACK/RST
0 0 RETURN icmp -- any any anywhere anywhere icmp echo-request limit: avg 1/sec burst 5
0 0 DROP icmp -- any any anywhere anywhere icmp echo-request
0 0 RETURN all -- any any anywhere anywhere
Chain SSHBFP (1 references)
2 180 all -- any any anywhere anywhere recent: SET name: SSH side: source
0 0 DROP all -- any any anywhere anywhere recent: UPDATE seconds: 60 hit_count: 4 name: SSH side: source
2 180 ACCEPT all -- any any anywhere anywhere
Chain logaccept (0 references)
0 0 LOG all -- any any anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `ACCEPT '
Chain logdrop (0 references)
0 0 LOG all -- any any anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix `DROP '
admin@RT-N66R:/tmp/home/root# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
192.168.0.1 * 255.255.255.255 UH 0 0 0 eth0
XXX.156.175.XXX 192.168.0.1 255.255.255.255 UGH 0 0 0 eth0
10.0.0.0 * 255.255.255.0 U 0 0 0 br0
192.168.0.0 * 255.255.255.0 U 0 0 0 eth0
10.4.0.0 * 255.255.0.0 U 0 0 0 tun11
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
default 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
