[SOLVED] Save/Load manually assigned DHCP IPs from file ?
busch09
Is there a way to save all manually assigned IPs to a file and load that file after a reset/ firmware upgrade ?
I have tried the tool to save/load a full config to USB but always have issues where the routers dont run properly when doing that, so I end up configuring everything from scratch with a merlin update.
Best
Chris
