[Solved] Setting Masquerade from webui
cowst
is it possible to set something like "iptables -t nat -A POSTROUTING -s "10.8.0.0/24" -j MASQUERADE" from the webui or I have to write some jffs script?
In the latter I suppose it would go in nat-start, right?
nat-start would be the correct location, yes.
I take it as a "no, there is no room in UI for such command" :p
I dared asking because it sounded similar to the custom commands in openvpn server :)
