amplatfus
With firmware 380.63_2 on AC88U spin down seems to not working accurate. I have 32400 (9 hours) as value set in Disk spindown idle time (in seconds) field.
But after few minutes the HDD spins down and I do not know why it does this so early.
I have done even factory reset but it still happens. Even I have set 0 in the idle time. I mention that I have been using same HDD on older Optware and at that time HDD never spin down.
Could you please confirm if spin down timer works OK or it has known errors?
It is a USB 2.0 HDD formated as EXT3. I have also swap file active on it with Entware-NG.
Thank you in advance,
amplatfus
amplatfus
