Hi guys,
I need some quick 'n dirty switch advice...
I want to setup a LAN. The router I'll be using will be the Draytek Vigor 2820n. Great router, with lots of features, but with only one downside... it's switch only comes with ONE gigabit port, the other three ports are 100 Mbit.
I'm aiming for a complete Gigabit network, so I need a decent Gigabit switch. The choice for that was easy: HP Procurve. My first choice would have been the 1800 series, but because of the incompatibility of the 1800 series with the Sonos music system, I can't use that range.
I need about 36 drops on this LAN, so I could either buy one 48 port switch, or two 24 port switches.
Now, I was wondering: If I buy two ProCurve 1400's (unmanaged switch), and keeping into account that the Draytek router only has one gigabit port, could I then use these two switches, by plugging the first switch into the router's gigabit port and the second switch into the first switch? (sorta like 'daisy chaining' these switches?) Does that work? (My first choice would have been to BOTH connect these switches to the router, but as said, since the Draytek only features one gigabit port, this isn't really an option...)
I'm also considering buying the MUCH more expensive 44 port ProCurve 2510G-48 (J9280A - bottom of the page) switch. But I'm not 100% sure if this is a full gigabit switch. The site does mention that 'each port can be used as either an RJ-45 10/100/1000 port', but what are those 4 dual personality ports for then?
This switch would be about twice the price as two 1400's but since it's a manageable switch, I'm guessing it would be a lot more fun too. (anybody know where I can read a review about this switch?) Oh, and this switch can also be managed through a web interface utility I hope?
If somebody would know an answer to my questions, I would be most grateful.
Cheers!
Cheers!
