Sony Blu Ray Streaming issues
CivHunter
I just picked up an RT-AC87R to replace my current RT-AC66R and I flashed the 87R to the current version of the Merlin firmware. All of my devices connect and work normally with the exception of my Sony BluRay player. It connects wirelessly on 2.4ghz and it shows it connected and I do a diagnostic on the bluray player and it says the connection is good. The problem is when I attempt to load Netflix or Pandora it gives me an error that the content can not be loaded. With the AC66R I had no troubles streaming. Just hoping someone had an idea on a setting I may have overlooked?
Found it
I found the setting that was stopping the blu-ray player from streaming content.
Wireless>>Professional>>2.4GHz>>Enable IGMP Snooping>>Enable
Not sure if the IGMP had defaulted to Disable or if I had turned it off thinking of security but once I toggled it on the blu-ray player began to stream content quite nicely. :)
D Sony Pictures Core Website Blocked Asuswrt-Merlin 9
