Sorry if I'm rehashing old ideas, but I need help!
timmyc99
Hey all - I've been reading a ton of forums for the past month, and while I glean bits of info all over the place, I'm still in a bit of a quandary.
Here's my situation:
For a few years I've been ripping my dvds and putting them on an an old desktop which has been functioning as an HTPC and a torrent box. I've been streaming through my Xbox360 and administering the box via RDP. It's an old Pentium D 3.0 w/ 4gb RAM that is really on its last legs - doesn't even have a video card in it anymore.
Now, that computer has been running without any kind of backup for the entire time. (I know, I know... :) ) As my collection has grown, I've been getting more and more paranoid about HD failure or some other kind of data loss. As such, I'm looking at buying a full fledged NAS.
My requirements:
-Preferably 4 bay, as to provide lots of future storage space and a wider variety of RAID configs.
-Has to be able to stream via uPNP/DLNA etc to my xbox, though I may at some point buy a different media extender.
-Has to be able to run a full fledged BT client, seeding a lot (usually 100+) though not usually more than 3-4 simultaneous downloads (and all this while streaming video if necessary). I have a 20Mb connection, which tops out at about 3000kb/s down.
-Would like some kind of WAN support - I do travel a fair bit, or am on non-home networks, and would like to be able to access my media for streaming, not just downloading to a remote client.
-NAS will be wired to a gigabit network; Xbox is wired as well, there are a few wireless clients also - would like easy access to files via wireless clients.
-NAS will also be set up to backup wireless clients when they are local.
I've been looking a lot at the QNAP TS-459 Pro/Pro+ and a bit at the Synology DS1511+. I like the looks of the Synology, but it seems like their multimedia support is somewhat lacking. I know they are probably overkill, but I want to be sure I have the horsepower to run a number of services without degrading performance. I've read a bit about FreeNAS, but it seems to function best as a pure NAS, not a hybrid box like I'm looking for.
I've been toying with the idea of going to DIY route, as it would be cheaper and probably more versatile but I don't have a lot of time to spend tinkering (I'm a medical student).. it's probably worth the money to me if I can find a readymade solution that will work out of the box. That being said, if the "ideal" device doesn't exist, I may be convinced to go with a DIY.
I'm probably going to start with 2x2TB drives in a RAID 1, then adding and migrating to RAID 5 or 6 in the future.
I'd like to come in under about 1100 to start.
Any help/questions/suggestions would be very much appreciated.
I've been going through a similar process, so I'll share the benefit of my research.
NOTE: These are all my opinions, based on trolling online resources looking for knowledge from other people's experiences, and from comparing their products with a fine toothed comb.
The following products are all 4 bay drives;
fairly newer products in each supplier's line (meaning you'll get newer hardware spec, etc.);
priced approx. $699 retail OR LESS (which means that you should be able to add 4 x 1TB drives to each of them and come in around budget).
ReadyNAS Ultra 4
ReadyNAS Ultra 4+
Qnap TS-459P+
Synology DS411+
Thecus 4200ECO
Each supplier has some older products that, while less beefy and less cutting edge, might also be able to fit the bill and come in cheaper:
ReadyNAS NV+
ReadyNAS NVX Pioneer edition
Qnap TS-459
Synology DS411j
Thecus N0503
In terms of the suppliers, here's what I've been able to gleen from trolling lots and lots of boards and web sites:
ReadyNAS:
Very good product, good tech support, tends to be pricey, 3yr warranty.
Note: none of their products in your price range has eSATA.
Qnap:
Good product, so-so tech support, good value, 1 year warranty.
Note: 1 year warranty was the #1 reason why I eliminated this product from my list.
Synology:
Very good product, good tech support, good value, 2 year warranty.
Note: No LCD/ LED readout, no hot-swappable drives. DS411+ looks like an old floppy disk storage box (u.g.l.y.), and the DS411j looks like it escaped from the set design shop for Star Trek: The Motion Picture.
Thecus:
Very good product, weak English language tech support, great value, 2 year warranty.
Note: If Thecus had better reviews for their English language service, and a 3 year warranty, this would be my product of choice. It has a great feature set, the software gets good marks, and the product looks really nice.
Thanks for the detailed information, ntepperman. Do you know the real differences between the DS411+ and the DS411j? They seem so very similar but the 411+ is nearly double the price.
And, yes, they are both hideously ugly. I really wanted a Drobo in the past and it seems like it has great features but the reviews have scared me.
Thanks a lot for the reply.. I hadn't really looked into the ReadyNAS at all, but the Ultra 4 Plus looks decent. Netgear uses Orb for its WAN streaming, though.. and Orb is seriously the worst. I used it for quite a while on this box for web streaming, and it is terrible. They also claim that Orb can work via your smartphone to stream.. look up orb in the Android Market and I bet you won't find a worse reviewed or supported app.
Does anyone have any experience with the multimedia capabilities of Synology? I'm sort of leaning toward QNAP, though the lackluster warranty worries me a bit.
You should really use the "Compare Products" function on Synology's web site for a thorough comparison.
Here are the main differences that I was able to identify:
DS411J
- 1.2GHz CPU
- 128MB RAM
- No eSATA
- No wake on LAN (I think)
DS410
- 1.06Ghz CPU
- 512MB RAM
- 1 eSATA
- wake on LAN
