Merlin,
Thanks for the great work. I've historically used dd-wrt on my routers, however I found with wanting to use a USB3 HDD off of a ac68u router that the throughput under dd-wrt was 25-30% of stock or your firmware. The one thing I saw that was "missing" was an option for setting the source IP for nat rules as there are certain things I want open to a single source. Any chance this gets added at some point. I did set up the nat-start script, along with the ddns-start script, both of which work fine. However the logging seems to be a bit lite. Any odds this gets any consideration, or would it require more work than it's worth?
