spdMerlin spdMerlin - Automated speedtests with graphs
Love your work, Just one issue with me not sure if its a bug or something else, the timestamps are GMT although my time zone is +10.00. is there anything can be done to fix or is this how it was intended.
Feedback wanted! Rather than having separate charts for download and upload, and a set of charts shown separately for each period, I'm considering opting for a combined chart, with a dropdown selector for the period you want to see, which would look something like this: https://puu.sh/FNOuF/089b74fc7d.png
What are people's thoughts on this? This isn't something that I can make "either or", and would be a replacement for the existing design which would cease to exist
NOTE: CSVs would still be exported for each period, but download and upload would be comnbined
Yes vote from me.
I sure think it is much better than the current graphs. Too much scrolling at the moment.
Yes for me.
- Will look a lot better and less scrolling to do.
- Would you also be able to accommodate my earlier request of starting the graph from 0 to max value?
i think this is a nicer use of display real estate, but the graph may need to have 2 scales (one on the left, one on the right), if the max speeds for up/down are quite asymmetric?
I contemplated dual axis, but my 350/35 connection looks OK. Added bonus, clicking the legend will show/hide the dataset so you can focus on one particular metric:
does scale change when focusing on just one of the metrics?
my connection is 600/15
Hi all, when I use option 3 or 4 I get an error:
[: bad number
/jffs/scripts/spdmerlin: line 1921: jq: not found
1956)
Also I cannot use Option 2:
Choose an option:    2
spdMerlin: Starting speedtest using None configured for WAN interface
[2020-05-23 17:16:53.319] [error] Configuration - Specified invalid server ID number (InvalidServerId)
Error: near line 2: near ",": syntax error
spdMerlin: Speedtest results -  -
Press enter to continue...
Did I miss something in the settings ?
[: bad number
1956)
Choose an option:    2
try
opkg update && opkg install jq
Yes for me.
Thanks for all the constant improvements.
