Plompie
Hi all,
Since last update spdMerlin did not show any results in the graphs anymore and scheduled test were not running. Logged into AMTM via SSH and when trying to open de spdMerlin option (j4) I received below message. Restarted the router, tried to remove the scrip manually for re-install but no luck, the error keeps coming back.
Any idea's how I could get it running again?
Initial error: (AMTM -> j4)
Could not access the script within AMTM so looked up the directories and files and manually removed:
After above manual removal: (retried install via AMTM)
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Upgrading database...
/jffs/addons/spdmerlin.d/
/jffs/scripts/spdmerlin
/tmp/spdmerlin-binary
/tmp/spdMerlin.lock
/tmp/spdstats-upgrade.sql
/tmp/spd-stats.txt
Welcome to spdMerlin v4.4.1, a script by JackYaz
By installing spdMerlin you are agreeing to Ookla's license: https://raw.githubusercontent.com/jackyaz/spdMerlin/master/speedtest-cli-license
Do you wish to continue? (y/n) y
Checking your router meets the requirements for spdMerlin
Installing required packages from Entware
Downloading https://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package sqlite3-cli (3330000-2) installed in root is up to date.
Package jq (1.6-1) installed in root is up to date.
Package p7zip (16.02-3) installed in root is up to date.
Package findutils (4.8.0-1) installed in root is up to date.
New version of spdstats_www.asp downloaded
Mounting WebUI tab for spdMerlin
Mounted spdMerlin WebUI page as user3.asp
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
