Speed goes down after few days on AC86U...
gizimo
i have installed Merlin 384.10.2 on my Asus, i am using it with a OpenVPN connection. I have the Problem that after few days the bandwith on the Router goes down from 50Mbit to 2 - 1 Mbit. After a reboot it works normaly.... does somebody else has this problem?
As many can attest to, an M&M config is the only thing that has worked for them to get them the 'speed' back. ;)
Please see my signature to the links and further details on how to get your router to a good/known state. It doesn't seem to be there now. ;)
Pay attention to the details in the link provided by L&LD in the above post. Don't deviate, they matter. Also if you have a saved backup I would suggest you delete it now as any issue's your having have been saved also. Once you get your router in a stable state then do another backup.
