spdMerlin Speedtest Data Usage > 1GB
Kanji-San
@Jack Yaz: I noticed that sometimes when the data usage for a download or upload exceeds 1 GB then the columns "Download Data (MB)" and "Upload Data (MB)" contain e.g. 1.0 instead of 1024.
For example a speed test outputs:
Bandwidth - Download: 859.44 Mbps (data used: 1.0 GB ) - Upload: 939.96 Mbps (data used: 1.2 GB )
Quality - Latency: 7.02 ms (0.33 ms jitter) - Packet Loss: 0.0%
Would it be possible to adjust the GB data in the table (and CSV) to MB so it's correct?
Thank you.
