SSH between 2 routers - trouble setting up keys
mcouture
I am having trouble with being able to have SSH between 2 routers using keys.
I can get it so my workstation can Putty into the routers with keys, but I cannot get dropbear to work between both routers.
Latest try:
- dropbearkey -t rsa -f id_rsa
- create the id_rsa.pub from the output above (just the public section)
- copy id_rsa.pub to remote router (into GUI)
- on local router, ssh -i id_rsa userid@far-router-address
What am I missing?
What error are you getting?
Couple of things to check:
  • I'm assuming you are allowing ssh connections from outside, in your remote router (just mentioning this in case you overlooked)
  • See if your remote router's port 22 is visible from your local router (if you have entware, install nmap and try nmap -p T:22 <remote_router>)
  • If you are able to, also make sure the ~/.ssh/authorized_keys on the remote router has 600 or 700 for octal permissions (if you are doing it in the UI, this should be automatically done)
Ah shucks....
It looks like I copied the public key with the "fingerprint" line....so once I got that out of there, I am able to ssh without passwords!
Thanks for helping redhat27!
