SSH Brute Force Attacks
bpearse
I see that there is an option under "Administration/System/Miscellaneous" for Enable Brute Force Protection. I am curious what this option does. Does it adjust iptables similar to this thread?
Iptables settings against attacks
Yes. It limits connection attempts to sshd to a maximum of 4 every 60 seconds from a given IP.
Yes, it creates this chain:
Chain SSHBFP (1 references)
target     prot opt source               destination
           all  --  anywhere             anywhere            recent: SET name: SSH side: source
DROP       all  --  anywhere             anywhere            recent: UPDATE seconds: 60 hit_count: 4 name: SSH side: source
ACCEPT     all  --  anywhere             anywhere
Not working?
Uh, I have the Brute Force Protection enabled in GUI, but it does not seem to help. Here is my 'China Syndrome' from syslog. Maybe need to adjust the variables, as in 4 attempts every 60 minutes?
Oct  7 20:00:08 dropbear[1096]: Login attempt for nonexistent user from 203.199.194.66:50870
Oct  7 20:00:09 dropbear[1096]: Exit before auth: Disconnect received
Oct  7 20:00:10 dropbear[1097]: Child connection from 203.199.194.66:51077
Oct  7 20:00:13 dropbear[1097]: Login attempt for nonexistent user from 203.199.194.66:51077
Oct  7 20:00:14 dropbear[1097]: Exit before auth: Disconnect received
Oct  7 20:00:15 dropbear[1098]: Child connection from 203.199.194.66:51256
Oct  7 20:00:17 dropbear[1098]: Login attempt for nonexistent user from 203.199.194.66:51256
Oct  7 20:00:18 dropbear[1098]: Exit before auth: Disconnect received
Oct  7 20:08:04 dropbear[1099]: Child connection from 199.115.230.115:59952
Oct  7 20:08:04 dropbear[1099]: Exit before auth: Exited normally
Oct  7 20:12:23 dropbear[1100]: Child connection from 199.115.230.115:52947
Oct  7 20:12:24 dropbear[1100]: Login attempt for nonexistent user from 199.115.230.115:52947
Oct  7 20:12:25 dropbear[1100]: Exit before auth: Disconnect received
Oct  7 20:12:25 dropbear[1101]: Child connection from 199.115.230.115:53295
Oct  7 20:12:26 dropbear[1101]: Login attempt for nonexistent user from 199.115.230.115:53295
Oct  7 20:12:27 dropbear[1101]: Exit before auth: Disconnect received
Oct  7 20:12:27 dropbear[1102]: Child connection from 199.115.230.115:53421
Oct  7 20:12:28 dropbear[1102]: Login attempt for nonexistent user from 199.115.230.115:53421
Oct  7 20:12:29 dropbear[1102]: Exit before auth: Disconnect received
Oct  7 20:20:25 dropbear[1103]: Child connection from 199.115.230.115:57995
Oct  7 20:20:26 dropbear[1103]: Login attempt for nonexistent user from 199.115.230.115:57995
Oct  7 20:20:27 dropbear[1103]: Exit before auth: Disconnect received
Oct  7 20:20:27 dropbear[1104]: Child connection from 199.115.230.115:58215
Oct  7 20:20:28 dropbear[1104]: Login attempt for nonexistent user from 199.115.230.115:58215
Oct  7 20:20:29 dropbear[1104]: Exit before auth: Disconnect received
Oct  7 20:20:29 dropbear[1105]: Child connection from 199.115.230.115:58482
Oct  7 20:20:30 dropbear[1105]: Login attempt for nonexistent user from 199.115.230.115:58482
Oct  7 20:20:31 dropbear[1105]: Exit before auth: Disconnect received
Oct  7 20:28:25 dropbear[1106]: Child connection from 199.115.230.115:43132
Oct  7 20:28:26 dropbear[1106]: Login attempt for nonexistent user from 199.115.230.115:43132
Oct  7 20:28:27 dropbear[1106]: Exit before auth: Disconnect received
Oct  7 20:28:27 dropbear[1107]: Child connection from 199.115.230.115:43339
Oct  7 20:28:28 dropbear[1107]: Login attempt for nonexistent user from 199.115.230.115:43339
Oct  7 20:28:29 dropbear[1107]: Exit before auth: Disconnect received
Oct  7 20:28:29 dropbear[1108]: Child connection from 199.115.230.115:43554
Oct  7 20:28:30 dropbear[1108]: Login attempt for nonexistent user from 199.115.230.115:43554
Oct  7 20:33:31 dropbear[1108]: Exit before auth: Timeout before auth
Oct  7 20:34:00 dropbear[1109]: Child connection from 199.115.230.115:46911
Oct  7 20:34:01 dropbear[1109]: Login attempt for nonexistent user from 199.115.230.115:46911
Oct  7 20:34:02 dropbear[1109]: Exit before auth: Disconnect received
Oct  7 20:34:02 dropbear[1110]: Child connection from 199.115.230.115:47123
Oct  7 20:34:03 dropbear[1110]: Login attempt for nonexistent user from 199.115.230.115:47123
Oct  7 20:34:04 dropbear[1110]: Exit before auth: Disconnect received
Oct  7 20:34:04 dropbear[1111]: Child connection from 199.115.230.115:47360
Oct  7 20:34:05 dropbear[1111]: Login attempt for nonexistent user from 199.115.230.115:47360
Oct  7 20:34:06 dropbear[1111]: Exit before auth: Disconnect received
Oct  7 20:41:51 dropbear[1112]: Child connection from 199.115.230.115:59077
Oct  7 20:41:52 dropbear[1112]: Login attempt for nonexistent user from 199.115.230.115:59077
Oct  7 20:41:53 dropbear[1112]: Exit before auth: Disconnect received
Oct  7 20:41:53 dropbear[1113]: Child connection from 199.115.230.115:59298
Oct  7 20:41:55 dropbear[1113]: Login attempt for nonexistent user from 199.115.230.115:59298
Oct  7 20:41:55 dropbear[1113]: Exit before auth: Disconnect received
Oct  7 20:41:55 dropbear[1114]: Child connection from 199.115.230.115:59554
Oct  7 20:41:57 dropbear[1114]: Login attempt for nonexistent user from 199.115.230.115:59554
Oct  7 20:41:57 dropbear[1114]: Exit before auth: Disconnect received
Oct  7 20:50:04 dropbear[1115]: Child connection from 199.115.230.115:46461
Oct  7 20:50:06 dropbear[1115]: Login attempt for nonexistent user from 199.115.230.115:46461
Oct  7 20:50:06 dropbear[1115]: Exit before auth: Disconnect received
Oct  7 20:50:10 dropbear[1116]: Child connection from 199.115.230.115:46660
Oct  7 20:50:11 dropbear[1116]: Login attempt for nonexistent user from 199.115.230.115:46660
Oct  7 20:50:11 dropbear[1116]: Exit before auth: Disconnect received
Oct  7 20:50:12 dropbear[1117]: Child connection from 199.115.230.115:47201
Oct  7 20:50:13 dropbear[1117]: Login attempt for nonexistent user from 199.115.230.115:47201
Oct  7 20:50:13 dropbear[1117]: Exit before auth: Disconnect received
Oct  7 21:00:00 dropbear[1118]: Child connection from 199.115.230.115:59508
Oct  7 21:00:01 dropbear[1118]: Login attempt for nonexistent user from 199.115.230.115:59508
Oct  7 21:00:02 dropbear[1118]: Exit before auth: Disconnect received
Oct  7 21:00:02 dropbear[1119]: Child connection from 199.115.230.115:59687
Oct  7 21:00:03 dropbear[1119]: Login attempt for nonexistent user from 199.115.230.115:59687
Oct  7 21:00:04 dropbear[1119]: Exit before auth: Disconnect received
Oct  7 21:00:04 dropbear[1120]: Child connection from 199.115.230.115:59905
Oct  7 21:00:06 dropbear[1120]: Login attempt for nonexistent user from 199.115.230.115:59905
Oct  7 21:00:07 dropbear[1120]: Exit before auth: Disconnect received
Oct  7 21:10:21 dropbear[1121]: Child connection from 199.115.230.115:47454
Oct  7 21:10:22 dropbear[1121]: Login attempt for nonexistent user from 199.115.230.115:47454
Oct  7 21:10:23 dropbear[1121]: Exit before auth: Disconnect received
Oct  7 21:10:23 dropbear[1122]: Child connection from 199.115.230.115:47616
Oct  7 21:10:24 dropbear[1122]: Login attempt for nonexistent user from 199.115.230.115:47616
Oct  7 21:10:25 dropbear[1122]: Exit before auth: Disconnect received
Oct  7 21:10:25 dropbear[1123]: Child connection from 199.115.230.115:47838
Oct  7 21:10:26 dropbear[1123]: Login attempt for nonexistent user from 199.115.230.115:47838
Oct  7 21:10:27 dropbear[1123]: Exit before auth: Disconnect received
4 attempts every 60 minutes would be a bit radical, as any legitimate trouble logging in would lock you out for a whole hour. The goal of limiting connections to 4 per minute is enough to ensure that it won't be possible to do any effective brute force attack, it's not meant to completely prevent them from trying. Notice that a lot of those connection attempts reoccur 8-10 minutes later, so the block is effective in slowing them down enough to ensure they can't force they way in.
Doh! You are right. I did not really notice the time stamps. So the iptables settings are indeed working as they should.
