SSH Listen on 2 Ports
john5788
I have an RT-AC68U running 384.13. Is it possible to run dropbear to listen on 2 ports?
I tried opening a new dropbear process:
# dropbear -p 8022 -a
But I cannot connect to it. Is this an iptables rule I need to add to open 8022 on the router itself so I can connect? netstat shows this port is open, but I cannot connect to it externally.
# netstat -an | grep 8022
tcp 0 0 0.0.0.0:8022 0.0.0.0:* LISTEN
tcp 0 0 :::8022 :::* LISTEN
Nevermind, solved it myself, it was an iptables rule I needed to add.
# iptables -I INPUT -p tcp --dport 8022 -j ACCEPT
And I can now connect.
I'm guessing if I reboot, I lose these changes. How would I go about making these 2 changes permanent on boot?
