SSID guest networks
Skywalker
Is it possible to use the same SSID for multiple guest networks? Just like I use the same SSID for 2.4 and 5 Ghz network.
No. Otherwise, the laptop would have no way to know to which network it should connect if you tell it "connect to myssid".
This is different with 2.4 GHz vs 5 GHz because both SSIDs sits on different channels.
More than 1 user on a guest account
Hi guys,
First post here, got my rt-n66u started yesterday.
When we are descended upon by a family kids, can they all use the same guest account (internet only) or do I need to set up one each?
Bob.
Hi guys,
Bob.
One guest network can be used by as many persons as you wish. So typically, you only need one guest network.
Two might be useful if you want one guest for the kids (with access to a NAS), and one for visitors (with only Internet access), for example.
I tried this for my kids and found that you can't set up parental controls with the guest network. But then again, the parental controls don't even work on the proper network??:mad:
G Where is my Guest Network UI tab? Facebook??? ASUS N Routers & Adapters 4
