SSID with custom DHCP subnet - internet doesn't work
Jack Yaz
Part of the Furniture
Using guides from the wiki, I've got the below dnsmasq.postconf. My device can connect to the guest network (which is configured via the WebUI), but no internet. Can anyone help?
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
logger "dnsmasq-dhcp: Configure wl0.1 to have special DHCP"
pc_append "
interface=wl0.1
dhcp-range=wl0.1,10.14.15.10,10.14.15.10,255.255.255.0,86400s
dhcp-option=wl0.1,3,10.14.15.1
dhcp-option=wl0.1,6,8.8.8.8
" /tmp/etc/dnsmasq.conf
ifconfig wl0.1 10.14.15.1 netmask 255.255.255.0
ip route show table main | grep -Ev ^default | while read ROUTE; do
ip route add table 10 $ROUTE;
done
ip route add default dev eth0 table 10
ip rule add dev wl0.1 table 10
ip route flush cache
ebtables -t broute -D BROUTING -i wl0.1 -p ipv4 -j DROP
ebtables -t broute -I BROUTING -i wl0.1 -p ipv4 -j DROP
ebtables -t broute -D BROUTING -i wl0.1 -p arp -j DROP
ebtables -t broute -I BROUTING -i wl0.1 -p arp -j DROP
iptables -D INPUT -i wl0.1 -m state --state NEW -j ACCEPT
iptables -I INPUT -i wl0.1 -m state --state NEW -j ACCEPT
iptables -D FORWARD -i wl0.1 -o eth0 -j ACCEPT
iptables -I FORWARD -i wl0.1 -o eth0 -j ACCEPT
iptables -t nat -D POSTROUTING -s 10.14.15.0/24 -o eth0 -j MASQUERADE
iptables -t nat -I POSTROUTING -s 10.14.15.0/24 -o eth0 -j MASQUERADE
Are you sure your append works? I have not tried it for fear I break mine.
But a proper approach would be as the example given in the wiki:
CONFIG=$1
pc_append interface=wl0.1 $CONFIG
On second thought, yours might actually work as you only append, not replace.
CONFIG=$1
I've nano'd the updated conf file in etc and seems to be OK
Which works, but DHCP is serving me .184, when the pool starts at .2, so I must have a conflict somewhere
The address you get is based on a hash of the mac address.....it doesn't run sequentially in the pool range.
