Start / stop guest wifi ssh
lbradio
I was wondering: is it possible to start / stop a (already configured) guest wifi by SSH?
I would like to put this in a cron.
Kind of an ugly way. It will kill your wifi briefly. I have no idea if some clients can associate to a blank SSID, my android phone won't anyway.
# Bring down guest network
wl down
wl ssid --cfg=1  <-- make sure this is the guest network
wl ssid --cfg=1 ""   <--- blank out the ssid
wl up
# Bring up guest network
wl down
wl ssid --cfg=1 "OLD_SSID"
wl up
wl down
wl ssid --cfg=eth1  <-- make sure this is the guest network
wl ssid --cfg=eth1 ""   <--- blank out the ssid
wl up
wl down
wl ssid --cfg=eth1 "OLD_SSID"
wl up
I have been playing with your solution, but it seems something is not right yet.
wl ssid --cfg=wl0.1 (wl0.1 seems to be the guest network) results in:
 ssid: could not parse "wl0.1" as an integer for the configuartion index
ssid    Set or get a configuration's SSID.
        wl ssid [-C num]|[--cfg=num] [<ssid>]
        If the configuration index 'num' is not given, configuraion #0 is assumed and
        setting will initiate an assoication attempt if in infrastructure mode,
        or join/creation of an IBSS if in IBSS mode,
        or creation of a BSS if in AP mode.
But I continued with your idea of changing SSID to "" <blank>.
After a while I've tried the following code:
wl down
nvram set wl0.1_ssid="test"
nvram commit
wl up
which actually does change ssid on the ASUS Guest Network page. However, it does not broadcast the new SSID yet. I think some services has to be stopped and started for activating. When I enable another guest network on the ASUS page, the changed SSID IS shown. So I need a trigger.
Any suggestions?
Sorry I messed up.
--cfg=1
not --cfg=eth1
OK, now it's working :)
For 2,4GHz it is:
wl down
wl ssid --cfg=1 ""
wl up
When disable Guest network and enable it back, old values re-appear, whitch is ok.
Two questions left:
1. what about 5GHz. Should it be as easy as change --cfg=1 to --cfg=2? (already tried that, doesn't work :) )
2. When I do want to change ssid permanently, nvram should bring the solution. But I need to activate the changes. Any ideas howto?
wl down
nvram commit
wl up
Thanks.
1. 5ghz
wl -i eth2 ssid --cfg=1
2. Not sure. Reboot? :confused: You'd have to look at the source code to see how the guest page brings interfaces/ssid's up and down the correct way. This method is just the quick-n-dirty way.
1. 5ghz
Ok. Also 5Ghz is working. Thanks.
I assume this source code is not public available? :)
I know the command for restarting dnsmasq is service restart_dnsmasq. However, I couldn't find any other service names, f.i. wireless.
You can do a "service restart_wireless" but it will restart the whole wireless subsystem and its dependencies (such as networkmap).
I've noticed that disable / enable guest network on the webpage also close down wifi for a few seconds, for me this is not a big issue.
Thanks for your answer, restart_wireless it is.
