Start VPN client remotely on asus-merlin
busch09
is there a way to start the vpn remotely on my asus-merlin ?
Id like to start a VPN to watch some foreign movies but dont want it on all the time. login in to the router, clicking to vpn settings and on seems cumbersome.
Is there a shortcut ?
cheers
buschi
Ideally, you would need VPN to login to your router...
Can't see it becoming less cumbersome than simply leaving it on.
cheers
buschi
The command to start the vpn client is
service   start_vpnclientX
where X is 1 or 2
So from my windows PC, I used to use a .BAT file (but now I use a more flexible Autoit .AU3 script) to run scripts on the router, but basically the technique is pretty simple.
set rHOST=192.168.1.1
set rPORT=22
set rUSER=admin
set rPASS=xxxxxxxxxxxx
set cCOMMAND=service start_vpnclient1
@plink.exe   -ssh   %rHOST%   -P   %rPORT%   -l   %rUSER%   -pw   %rPASS%   -batch   `%cCommand%   %arg1%   %arg2%`   2>&1
Usually I run the adblocker on the router, but for some sites, I need to disable the dnsmasq.conf.add entries or switch the dnsmasq.conf.add entry for UK/USA Netflix etc. so you may need to write a 'wrapper' script to perform any pre-actions then include the call to 'service start_vpnclient1'
