If someone has the time could you please tell me what the correct startup procedure is for a modem/router setup? Do you connect all the ethernet cables before powering on? Do you then power up the modem and then the router? Or maybe power up both the modem and then the router and THEN connect the cables? Simple stuff but I've been fumbling through it different ways and just wanted to know. Documentation doesn't talk much about it. Thank you.
