Static ARP entries lost
Boyderama
Hello everyone,
A week ago I created a services-start script to add several static ARP entries.
It's worked fine until today. I took a look at the ARP list and my static (PERM) entries were not present.
I rebooted the router and they came back as usual.
Is there a scheduled script which clears out all ARP entries including those set manually?
I use this command:
arp -s 192.168.111.120 28:92:4A:38:35:78
What could cause them to be cleared?
I am running Merlin firmware: 378.51 on an RT-N66U.
Many thanks
Nothing scheduled on the router itself, maybe something else (the kernel?) is expiring those entries.
A workaround would be to reapply those entries every few hours (or every hour), through a cron job.
Hi RMerlin.
I'm going to check daily to see if/when the ARP entries are removed. That will give me an idea of how often the cron job should run.
Many thanks for the advice.
