Static Routes - N66U
dan_miles86
Hi all,
I have two routers, primary is a Asus RT-N66U with an IP of 192.168.16.1.
Secondary is a bespoke one from my company allowing access to just one IP. For testing purposes lets say its 208.64.38.55 and the router IP is 192.168.16.2.
Both routers are connected LAN side to the same switch.
My DHCP is set with 192.168.16.1 as the gateway.
Therefore I have set 1 static route on the N66U as follows.
Host IP: 208.64.38.55
Netmask: 255.255.255.255
Gateway: 192.168.16.2
Metric: 1
Interface: LAN
Now when I TRACERT 208.64.38.55 I can see 192.168.16.2 as the second hop, all other traffic correctly exits from 192.168.16.1.
However when I try to use anything other than ICMP to 208.64.37.55 nothing happens, so I cant reach a site on port 80.
What am I doing wrong?!
