Stealth Mode
I do have an AC68U and I enabled the Stealth mode. The problem is now that after some time, the USB 2.0 LED turns on although Stealth mode is working. How can I turn off all LEDs all the time?
Why don't you just use the button on the back of the router to disable the LEDs? Is there something I am missing? That's what I use to have all the LEDs turn off.
This problem was also reported previously: http://forums.smallnetbuilder.com/showthread.php?t=17633&highlight=stealth+mode
Cheers,
fir3drag0n
As Merlin stated in that thread that creating a timer would be a waste of CPU resources. I have the same issue on a N66U. After about 15 minutes the USB drive lights comes back on then when I restart the LED service it goes off for a while and then back on again. You may want to setup a cron job to restart the LED service based on how often your light comes back on.
