Hi,What command-line commands.
On the router with the latest Tomato after running StealthMode constantly lit LED 5GHz WiFi. Does your software is the same problem?
How to run StealthMode the router RT-AC66U Latest version of your firmware? What command-line commands.
Alpha 3 misses that tab, enter, in your case:Thank you merlin for your prompt reply, you are a true wizard.
View attachment 8236 View attachment 8235 I dont have any other settings tab in my ui's anymore. I have an ac66 and an ac68, both on 380.65-3
Im sure they were there in older builds..
Thank you!If you take the risk to run *alpha* software, it's critical to read all information posted about that alpha version.
Welcome To SNBForums
