Stock doesn't seem to use swconfig to configure IPTV VLANs!?
aalba86U
The device is a RT-AC1300UHP. Curious to know how stock manages to configure IPTV+
VLANs when it doesn't seem to fully use swconfig. swconfig only shows partial information
and enable_vlan = 0!
@RMerlin you mentioned in another thread that for eth1-switch there is a user-space tool
for configuration. I read up a bit on robocfg/swconfig but stock firmware seems to do
something slightly different.
Example:
switch0: QCA AR8327 AR8337(QCA AR8327 AR8337), ports: 7 (cpu @ 0), vlans: 128
--switch
Attribute 1 (int): enable_vlan (Enable 8021q VLAN)
Attribute 2 (int): max_frame_size (Set Max frame Size Of Mac)
Attribute 3 (none): reset_mibs (Reset All MIB Counters)
Attribute 4 (none): flush_arl (Flush All ARL table)
Attribute 5 (string): dump_arl (Dump All ARL table)
Attribute 6 (unknown): switch_ext (Switch extended configuration)
Attribute 7 (none): apply (Activate changes in the hardware)
Attribute 8 (none): reset (Reset the switch)
--vlan
Attribute 1 (int): vid (Configure Vlan Id)
Attribute 2 (ports): ports (VLAN port mapping)
--port
Attribute 1 (none): reset_mib (Reset Mib Counters)
Attribute 2 (string): mib (Get Mib Counters)
Attribute 3 (int): pvid (Primary VLAN ID)
Attribute 4 (string): link (Get port link information)
switch_stb_x=6
switch_wan0prio=0
switch_wan0tagid=10
switch_wan1prio=4
switch_wan1tagid=20
switch_wan2prio=4
switch_wan2tagid=30
switch_wantag=manual
IPTV Profile: Manual
Internet: 10
LAN3/VoIP: 30
LAN4/IPTV: 20
This works fine. But swconfig doesn't show the information.
swconfig dev switch0 show
enable_vlan = 0
MAC: 00:90:f5:f0:fc:33 PORTMAP: 0x20 VID: 0xa STATUS: 0x0
MAC: f4:f9:51:f1:b7:33 PORTMAP: 0x08 VID: 0x1 STATUS: 0x0
MAC: 4c:ed:fb:36:10:e4 PORTMAP: 0x01 VID: 0x1 STATUS: 0x0
MAC: 00:90:f5:f0:fc:33 PORTMAP: 0x20 VID: 0x1e STATUS: 0x0
MAC: 4c:ed:fb:36:10:e0 PORTMAP: 0x01 VID: 0xa STATUS: 0x0
No VLAN 20 0x14
swconfig dev switch0 vlan 10|20|30 get ports
- all empty! It doesn't show ports like vlan 20: '0t 4t' etc
swconfig dev switch0 port N get pvid
- all show 0
G NextDNS on Stock firmware ASUSWRT - Official 5
