I have starting to use ASUS OpenVPN Server only recently.
As I was looking at my logs and I noticed something strange that will happen about every 12 hours from IP address in the range of 185.200.118.xx. The following is one example:
Questions:
- Jul 21 06:05:28 vpnserver1[732]: 185.200.118.42:40191 TLS: Initial packet from [AF_INET]185.200.118.42:40191 (via [AF_INET]116.87.159.239%eth0), sid=12121212 12121212
- Jul 21 06:06:28 vpnserver1[732]: 185.200.118.42:40191 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
- Jul 21 06:06:28 vpnserver1[732]: 185.200.118.42:40191 TLS Error: TLS handshake failed
- Jul 21 06:06:28 vpnserver1[732]: 185.200.118.42:40191 SIGUSR1[soft,tls-error] received, client-instance restarting
Questions:
- Should I be concern?
- What can I do?
